Activity Forums DVD Authoring Menu Creation
  • Menu Creation
    Posted by Tony Gates on July 24, 2009 at 5:05 am
    I want an object (a guitar pick) cretaed in Photoshop to appear when buttons are seleted then higlighted when activated, but transparent on normal state. I have these built in PS as part of the layer hierarchy.
    Help!
    Michael Sacci replied 17 years, 1 month ago 2 Members · 4 Replies
  • Michael Sacci
    July 25, 2009 at 3:42 am
    What program are you using? Is this a simple shape of the pick, or an image of a pick (with texture?)
  • Tony Gates
    July 25, 2009 at 3:12 pm
    Michael,
    I created menus in Photoshop CS3. I am authoring in Sonic DVDit PRO 6.4 that apparently allows composite menu editing. It does not appear to be as robust a tool as advertised.
    I also have DVD Studio Pro 3 on my iMac, but I prefer the VBR transcoding of my Progressive Mpeg2 in Sonic DVDit Pro though.
  • Tony Gates
    July 26, 2009 at 3:52 am
    Ton answer your first questions. The guitar picks are textured picture objects. The idea is that they go along with the rollover for selected the title on a menu.
  • Michael Sacci
    July 28, 2009 at 4:42 am
    Then you have to use the Layered Menu option. The navigation is much slower and doesn’t work the same on a set top vs software player.
    Each state is on a different layer. The manual does over this fairly well.
    I try to stay away from layered menus, so does almost every retail DVD.
