Activity Forums DVD Authoring Menu buttons as images
  • Menu buttons as images
    Posted by Peter Hammett on August 4, 2011 at 6:45 pm
    I have tried just about every freeware out there trying to find a way to have an image as a DVD menu button and I have not had much luck. I got close with “AVS DVD Authoring.” This software let me use an image as a button, however, my image is a .png file with some transparency and the software rendered the transparency as white. So my question is: is there any free DVD authoring software with which I can make a DVD menu with a .png as a button and retain the transparency? Any help is greatly appreciated!
    Andreas Gumm replied 15 years, 1 month ago 2 Members · 1 Reply
  • Andreas Gumm
    August 8, 2011 at 5:15 pm
    Button creation (button = subpicture for highlighting) is hardly limited by the DVD spec!
    You can use a maximum of 4 colors to create a valid subpicture stream for button indication!
    Normaly one color is set to 100% transparency. The other colors are set for outline, background & (pseudo-)antialising!
    Images are improper for the usage as button highlights! All other graphical ‘buttons’ with more complexity are realized with with the background image or video clip!
    Andreas Gumm
    selfemployed media author
