Activity Forums Adobe Encore DVD Menu button activation and non-smooth transition to animation menu fade out… help
  • Menu button activation and non-smooth transition to animation menu fade out… help
    Posted by Jimmilina on November 28, 2005 at 10:15 pm
    a tiny problem, but an annoying one.
    Encore 6.0
    I have a menu with two buttons. Each button links to a film clip of the menu fading out followed by its unique followinbg clip.
    However, when the button is clicked [in preview mode] there is a flash of black or a single frame of black occurs and instead of a smooth menu fade out and then into another clip… it jerk-flashes this black screen first then continues.
    What’s the deal? How can I fix it?
    …jim
    Jimmilina replied 20 years, 9 months ago 2 Members · 2 Replies
  • David Garrett
    November 29, 2005 at 9:07 am
    the dip to black should’nt be so noticeable on the burned disc. Try using a DVD RW disc just to check all is ok before you commit to a DVD R disc.
    You mentioned Encore 6.0!!! Encore is only at version 1.5 at this point in time
  • Jimmilina
    November 29, 2005 at 8:06 pm
    thanks a ton. i’m a bit new with Encore and just getting into the ‘fancier’ treatments.
    thanks again, i’ll try it.
    …jim
