Activity Forums DVD Authoring menu aspect and pixel settings
  • menu aspect and pixel settings
    Posted by Brian Cooney on March 30, 2010 at 5:24 pm
    need advice on how to take a psd menu in 3200×1800 (pixel dimensions 16.5M) Bicubic and keep the sharpest downsized image. The media is 720×404 . when I downsize (this is a ridiculously large file to shrink down…but it’s what the client wants soo…)
    ok.. the media is 720×404. (apple compressed m2vs). When I downsize the menu in photoshop I get 720×405. When I import it into DVDSP it gets slightly skewed.. making the text not clear. I’m wondering what pixel aspect ration I should be downconverting to. DVNTSC 4:3 and then let set DVDSP to letterbox/panscan to stretch out? tried that but didn’t work great. any ideas?
    I’m stuck with these assets and it hs to be done by order of the client (even though I don’t agree with the way it was provided) but what’s the best way? I’m thinking of re-doing all the text in DVDSP.. not sure what will achieve the optimal results under the circumstances. trying everything.
    Brian Cooney replied 16 years, 1 month ago 2 Members · 6 Replies
  • Brian Cooney
    March 30, 2010 at 5:30 pm
    BTW: forgto to mention that original menu (3200×1800) is in square pixels…
  • Brian Cooney
    March 30, 2010 at 5:39 pm
    wondering if I should change the original psd menu to rectangular pixels… then downsize.. the 720×404 video content looks good in rectangular obviously..
  • Rich Winter
    March 30, 2010 at 7:17 pm
    Scale down from 3200×1800 to 720×480 using Bicubic Sharper. You’ll have an anamorphic image at this point, but if you change the pixel aspect ratio to widescreen, you’ll see it in its correct aspect ratio.
    *- blackbird digital studios
    *- dvd design, editorial and production
    *- marin county, california, usa
    *- https://www.blackbird.tv
  • Brian Cooney
    March 30, 2010 at 8:58 pm
    thanks so, I downconvert to 4:3 720×240 and then use letterbox/panscan in DVDSP to expand it out?
  • Rich Winter
    March 30, 2010 at 9:09 pm
    exactly.
  • Brian Cooney
    March 30, 2010 at 9:38 pm
    thanks for the help. looks great!
