Activity Forums Adobe Encore DVD Menu animation
  • Menu animation
    Posted by Blanca Gras on August 5, 2009 at 12:19 pm
    Hi:
    I'm doing a job and I still like to help me because I tried to do one thing and not a thousand times I get. In the main menu of my project I have a white square that is adjacent to the first button and I would like to move every time you click another button to push that button that other. Is there a way to do?. This is my menu:
    Can you help? Thank you very much for your attention.
    White gras
    Paul Benson replied 17 years ago 2 Members · 1 Reply
  • Paul Benson
    August 6, 2009 at 11:43 am
    So, you want the white square to appear next to the words when the user presses the up and down buttons on the DVD remote? That is possible with the button highlights. Search for ‘encore menu button highlights’ and you should get quite a few hits. Here is one from Adobe:
    https://www.adobe.com/designcenter/encore/articles/enc15subpic.html
    Is the white square in your menu a button highlight, or is it drawn in as part of the picture? If it is a highlight, then you just need to copy that highlight to the other words (making sure you move it to the correct spot next to each word). If you drew it in as part of the picture, then you need to ‘erase’ it and use button highlights.
    Pauley
