Menu and quicktime questions
I am new to encore and have a few questions.
I’m making a DVD that contains a main menu, with about ten sections, which leads to sub menus which contain many options. These options will lead you to a screen that has a video playing in the middle, scrolling text next to it and buttons to return you to previous menus or to replay the video and text.
The menus will all use the same background and the same button is repeated, with different text.
Should I create each menu in photoshop or just import the background image and button psd, then add the text to the buttons in encore?
The videos I have been given, to play in the middle of the screen (not full screen) are in quicktime format. Is it possible to achieve what I’m trying?
Cheers,
Malcolm Angus
