Activity Forums Adobe After Effects Memory problem tracking 3k footage (PAL final output)
  • Memory problem tracking 3k footage (PAL final output)
    Posted by Christine Metcalf on October 27, 2008 at 11:00 am
    Hi All
    I have some 3k footage from a RED camera that I have imported into a composition in After Effects as Cineform Quicktimes.
    I am going out to PAL 720 x 576 as final.
    I am on a Quad Mac Pro with 4 gig of RAM and am getting memory errors from AE CS 3.
    I wonder if it is better to render out the clip to be tracked as PAL first and then track. This would help the RAM of the Mac but it would mean in AE there is less info to track.
    What would you guys advise?
    Christine
    Christine Metcalf replied 17 years, 10 months ago 2 Members · 2 Replies
  • Mark
    October 27, 2008 at 2:40 pm
    I would try rendering out to PAL first…just make sure that you pick the best possible output (CODEC) that you can.
    Mark
    Mark Harvey
    Senior Editor
    Le Réseau des sports
  • Christine Metcalf
    October 28, 2008 at 9:50 am
    Thank you very much, will do so
    Regards,
    Christine
