Activity Forums Zaxwerks memory error.
  • memory error.
    Posted by Mrj4k3 on November 2, 2005 at 10:35 pm
    Hello Folks,
    I am the proud owner of a Dell Precision Workstation 670 Dual Xeon 3.2GHZ with Two Gigs of Ram, I also have a nVidia Quadro FX 3450 PCI/Express 256MB.
    I’ve installed AfterEffects 6.5 and updated it to 6.5.1, also have installed Zaxwerks 3D Invigorator-AE Classic Version 3.1.2.
    I will be working with a project for a while, and then all of a sudden,
    After Effects error: Not enough memory to complete operation. (4)
    (25 :: 101)
    And I get a few of these with diffrent numbers, and then finally After Effects looks to be in trouble.
    I have updated the video drivers to the latest nvidia drivers,
    I have disabled open GL in the preview prefrences in After effects
    I have turned the Hardware Acceleration down to halfway
    I have disabled the “Desktop” profiles on the nvidia control panel
    I have uninstalled Windows XP x64, and formatted and reinstalled just regular Windows XP Professional and then did all the above
    I have redone the model.
    I have disabled norton antivirus
    I don’t know what to do next, is there anything else I can do? Here are some meaty system specs:
    Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 2 (2600.xpsp_sp2_rtm.040803-2158)
    Language: English (Regional Setting: English)
    System Manufacturer: Dell Inc.
    System Model: Precision WorkStation 670
    BIOS: Phoenix ROM BIOS PLUS Version 1.10 A06
    Processor: Intel(R) Xeon(TM) CPU 3.20GHz (4 CPUs)
    Memory: 2046MB RAM
    Page File: 369MB used, 5603MB available
    Windows Dir: C:\WINDOWS
    DirectX Version: DirectX 9.0c (4.09.0000.0904)
    DX Setup Parameters: Not found
    DxDiag Version: 5.03.2600.2180 32bit Unicode
    Card name: NVIDIA Quadro FX 3450/4000 SDI
    Manufacturer: NVIDIA
    Chip type: Quadro FX 3450/4000 SDI
    DAC type: Integrated RAMDAC
    Device Key: Enum\PCI\VEN_10DE&DEV_00CD&SUBSYS_029B10DE&REV_A2
    Display Memory: 256.0 MB
    Current Mode: 1280 x 1024 (32 bit) (75Hz)
    Monitor: Plug and Play Monitor
    Monitor Max Res: 1600,1200
    Driver Name: nv4_disp.dll
    Driver Version: 6.14.0010.7756 (English)
    DDI Version: 9 (or higher)
    Driver Attributes: Final Retail
    Driver Date/Size: 7/13/2005 15:33:00, 3880960 bytes
    WHQL Logo’d: Yes
    WHQL Date Stamp: n/a
    VDD: n/a
    Mini VDD: nv4_mini.sys
    Mini VDD Date: 7/13/2005 15:33:00, 3168352 bytes
    I’m running the 77.56 Version of the Nvidia driver, I don’t know what DXDiag is reporting here.
    Any help would be appreciated!!!!
    Matt Rhodes replied 20 years, 9 months ago 4 Members · 9 Replies
  • 9 Replies
  • Serge Hamad
    November 3, 2005 at 12:14 am
    You should contact the support team. Go to the Zaxwerks site to find the phone#…
    Salut & good luck.
    Serge
    PS: Let us know the fix please.
  • Mrj4k3
    November 3, 2005 at 12:44 am
    Hello and thanks Serge,
    I have contacted support, and they ask to try it on another machine or try with primitives. Well we bought this new machine specifically for this project, as we have some other older dogs sitting around. My boss is freaking out because I’m telling him that we need to regress to something circa 2001, and that this 1000 dollar video card could be the problem. So I’m really at a dead end. And the artist I’m working with is telling me that 3.1.2 classic doesn’t do primitaves. (I’m just the office computer guy.) I’m gonna try a diffrent video card tommorw.
  • Serge Hamad
    November 3, 2005 at 12:54 am
    Yes, try any cheaper video card before you change the station and loose the cpu speed…
    Your animator is right you can’t create primitives within Invigorator classic.
    Good luck.
    Serge
  • Matt Rhodes
    November 3, 2005 at 6:15 am
    Hi mrj4k3.
    One thing that would help us help you better is for you to tell us exactly
    what you’re doing when you get the error.
    For example:
    Are you doing a RAM Preview? A final render?
    Are you inside of the Invigorator Set-Up window?
    Are you using the Invigorator interface inside of the Effect Controls Window (ECW)?
    The more we know about what button you’re pushing or what function you’re using helps us a lot.
    Matt Rhodes
    Zaxwerks, Inc.
  • Mrj4k3
    November 3, 2005 at 8:24 pm
    I’m not the artist, I would have to get him to explain it. It goes something like this, he’s creating a tube and he uses an adobe illustrator file to define the extents of the tube. When he changes the FOCAL length of the scene, it bugs out. Also he can work from scratch just fine, then after he saves his work and re-opens it he gets the memory errors, and he finds that the focal length has been reset to default of 50. Also the color of the model will change from pink to black has he works with the preview. All this while the preview is off. Every time he works from scratch it’s okay, but once he saves, quits After effects, then re-opens the file it gives the memory errors.
    I’ll try and get the exact explination.
  • Mrj4k3
    November 4, 2005 at 10:08 pm
    Well I have the artist here, and he tells me that he was doing a RAM preview, and the RAM preview took too long, so he saved the scene or 3d object, and then re-opened it and thats when he got the error. Also he told me that he got the error from switching focal lenghts at one point as well. As far as the model goes his quote was, “It’s a very simple vector file from illustrator.” Once saved from this state it always then produces this memory error. I have also changed out the video card as well, to a Radeon X550 and we had some hope because the error didn’t seem to manifest itself as quickly, but sure enough still did crash. I have also loaded the latest ATI Drivers. So I’m still up a creek.
    Jake
  • Tom Daigon
    November 6, 2005 at 3:23 pm
    FWIW try testing another vector file, maybe one included with 3DI just as a point of comparison. It could be file relate…
  • Mrj4k3
    November 9, 2005 at 6:17 pm
    We tried that, he created just a flat box, or even a plane. Changed the focal length and
    the memory error. I advised the owner to either return the Dell, or Zaxwerks. I haven’t done anything more, since the artist is using his mac with his own copy of Zaxwerks at this time.
  • Matt Rhodes
    November 10, 2005 at 5:15 pm
    Hi mrj4k3.
    Sorry about the hassles.
    Could you tell me a series of steps having to do with focal length to do that would cause the memory error?
    It shoulds like you can create a repeatable memory error.
    Also, would you mind sending me a file that is giving you trouble?
    And could you tell how it’s giving you trouble?
    I’d like to help you get this resolved.
    Email your file (just the .aep) to: matt@zaxwerks.com
    Thanks.
    Matt Rhodes
    Zaxwerks, Inc.
