Activity › Forums › Adobe After Effects › memory dump while using AE6!
  • memory dump while using AE6!
    Posted by Chirag Hirani on July 9, 2013 at 6:10 am
    Hello everyone,
    I’m trying to render one video hive file ( got from client ). I’v finished editing like changing texts and images. not a big file not much heavy. after finishing i put it into render in PNG sequence. after rendering some images my pc popups BLUE MEMORY DUMP SCREEN with countdown.
    Is that memory issue ? I’v 4 gb ram and i’v given 2 gb to after effect.
    My config of pc is :
    AMD phenom XII1100T
    Asus Crosshair IV formula
    Asus HD5770 1gb DDR5 Graphic Card
    Transcend AXE Ram 2000mhz 4GB
    1tb hdd
    please help me with this issue.
    Thank you!!
    Chirag Hirani replied 13 years, 2 months ago 2 Members · 5 Replies
  • Chris Wright
    July 9, 2013 at 8:45 am
    google the really long error code. it will say ram or video card or hd.
    do a burn in test of your parts with hardware testing software to discover parts that overheat or fail under stress.
  • Chirag Hirani
    July 9, 2013 at 9:52 am
    Thank you. i will check all of them. hope it will gonna help me what to do!!
  • Chirag Hirani
    July 16, 2013 at 8:54 am
    I’v scanned my cpu, everything is ok. i used lover ver cs5 and it works little fine while working. but it crashes while end of rendering.
    should i increase my ram? any solution to stop crashing by memory dump?
  • Chris Wright
    July 16, 2013 at 10:50 pm
    try importing a tiff sequence and rendering out a tiff sequence. that will isolate any codec issues with interframe codecs or unsupported ones.
    Are you using PNG?, they are not thread safe for multiprocessing.
    Also, check with AE’s recommended RAM allocation.
  • Chirag Hirani
    July 17, 2013 at 9:10 am
    Thank you for replaying.
    yes i’m trying png sequence and also mov. and i’v allocated 2gb ram for after effect and another 2gb for other applications. also i’v moved catch allocation to different drive. i’v given 7gb for catch.
    after so much crashing i found one way, it’s little silly but it works.
    while rendering after some frame i pauses render and after 1-2 minutes continue rendering. sounds silly but i don’t know but that thing works and my pc stopped crashing. but that trick is not helping with cs6 only works with cs5.
    I will try with tiff. hope this will work well.
