Activity Forums Adobe After Effects Memory and RAM Cache settings CS3
  • Memory and RAM Cache settings CS3
    Posted by Jeff Blasczyk on July 1, 2009 at 9:14 pm
    I just went from 2 to 4 GBs of ram and I am still getting an image buffer warning for 5001×3336 image. I am uncertain what the ideal settings would be and how much vertial memory I need to have available.
    Compaq Presario F700 Notebook
    AMD Turion 64 x2 TL-60 2.00 GHz
    Ram: 4.00 GB
    32 bit operating system
    Kevin Camp replied 17 years, 2 months ago 2 Members · 3 Replies
  • Kevin Camp
    July 2, 2009 at 12:36 pm
    here’s a link to some good stps to follow to avoid image buffer errors:
    https://generalspecialist.com/2006/11/avoiding-after-effects-error-could-not.asp
    it’s a little old, but the settings will still apply to cs3… one other thing that you should do for cs3, is try disabling multiprocessing (preferences>multiprocessing, uncheck the option to render mulitple frames simutlaneously). with only 4gb of ram you won’t be able to effectively use multiprocessing anyway, and this will give more ram to the forground process, which is what you need.
    also, with 32-bit windows, there is a 4gb switch that needs to get set for windows to utilize all 4gb of ram. i don’t know the specifics, but search the the cow or the web for ‘windows 4gb switch ini’ and i’m sure it will turn something up.
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Jeff Blasczyk
    July 2, 2009 at 6:17 pm
    Thanks for all the info. I beleive all the RAM that AE can use is 3GB but the rest can be used for background processes. I finally figured out how to do a command prompt for a 3 GB switch in Vista.
    I tried rendering out last night but am still getting the image buffer error for an image 5001 by 3336. Hopefully messing with those settings mentioned in the link you provided will help.
  • Kevin Camp
    July 2, 2009 at 6:38 pm
    [jeff blasczyk] “I beleive all the RAM that AE can use is 3GB but the rest can be used for background processes”
    that’s correct
    [jeff blasczyk] “I tried rendering out last night but am still getting the image buffer error for an image 5001 by 3336. Hopefully messing with those settings mentioned in the link you provided will help.”
    even with the memory & cache settings, you may have to break up large images to get them to render without the image buffer error (the link mentions this, but i just wanted to reinforce that settings may not overcome this problem).
    you can also try to pre-render as much as you can by grouping layers into precomps (select the layers then choose layer>pre-compose, usually choose move all attributes) then, with the pre-comp open, choose composition>pre-render. set your render settings and render the pre-comp. a e will automatically import the render and replace the precomp in what ever comps are using it. this can reduce how much memory is needed to render the final comp, thus leaving more ram for the image buffer… how effectively you can utilize precomps and pre-rendering really comes down to your comp, though…
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
