Activity Forums Adobe After Effects Memory and Preferences
  • Memory and Preferences
    Posted by Matt Rinaldo on March 27, 2009 at 2:30 pm
    My computer is connected to an edit share (server) that allows everyone at my office to access to the file on it. All of my source footage is on the edit share.
    To get the best performance in after effects and from my mac, should I change the “conformed Media Cache” destination to a folder not on my computers hard drive? Would setting these destinations to our edit share system allow for faster renders and increased performance in aftereffects?
    If I do change these folders to the edit share will after effects know to look for the the information there? What should I title these folders?
    Also yesterday I received a openGL error message. I looked this up and found a thread that advised to turn off the Enable OpenGL in my Preferences menu. I did this and all is working fine now. Is this a common thing, it’s kind of bothering my because within the past two weeks I was given a new G5. Not the latest model that came out a few weeks ago, but the one prior to that, was purchased from Mac Mall.
    Any ideas if this new computer is to blame?
    Thanks for your time and sharing what you know, I appreciate it very much.
    Matt
    Todd Kopriva replied 17 years, 6 months ago 3 Members · 3 Replies
  • Jon Geddes
    March 27, 2009 at 8:17 pm
    I’ve never set the media cache to a network drive before, so I won’t be able to help you there.
    I can however comment on the Open GL. This is likely not an issue with your system, but rather a problem with After Effects. Many people have problems with the Open GL support, and its usually the first thing an expert will tell you to disable if you are having problems. If it works, thats great. If you have any kind of anomalies (crashing, errors, layers not displaying accurately), then it is advised to disable it.
    Jon Geddes
    Motion Graphics Designer
    http://www.precomposed.com
  • Matt Rinaldo
    March 27, 2009 at 8:59 pm
    Thanks for the clarification. I learned something new, you guys rock!
    Matt R.
  • Todd Kopriva
    March 28, 2009 at 5:12 am
    The only time that I enable OpenGL rendering is when I’m previewing an animation with a lot of 3D layers. It’s very valuable to have that faster preview available for such compositions, but I leave OpenGL rendering off at all other times.
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
