Activity › Forums › Adobe Premiere Pro › Memory and Error messages
Posted by South Video on January 28, 2007 at 6:53 pmHey, Been editing a 90 minute Hi def Program and been experiencing memery and shut down errors right at the end of this project, edit commands use to take 20 seconds are now 4 to 5 times that, very unstable, went from 1 to 3 ram space after experiencing the problem but still slow and unstable. been having a hard time burning DVD’s and exporting to tape, still running very slow.
Any suggestions?
Thank you!!!Mark
Bill Buchanan replied 19 years, 7 months ago 5 Members · 21 Replies -
Vince Becquiot
January 29, 2007 at 3:32 amYou haven’t mentioned your system specs, and whether or not you are editing rendered clips.
Vince
South Video
January 29, 2007 at 4:21 am2.0 Adobe Prem. on Dell 2.8 Ghz and 3 GB of Ram, 500 Hard Drive have a 7Nvida Geforce 7300, thinking of upgrading to 512?
It is rendered.
Thanks!Mark
Vince Becquiot
January 29, 2007 at 4:59 amFor HD, memory will not do much about speed, but the CPU will take most of the load. A dual core is probably going to be needed as part of the upgrade to get a stable machine. Do a Ctrl Alt Del > Performance, and I’m sure you’ll see your CPU stuck at 100%.
Good luck,
Vince
South Video
January 29, 2007 at 5:44 amHi Vince, Thank you for the info.
So you are saying I need a dual performance CPU?
Will check it out and let you know.Mark
South Video
January 29, 2007 at 7:57 amHiVince, It appears to have plenty of space on the CPU.
Any other ideas?
Thanks!Mark
South Video
January 29, 2007 at 7:59 amIt seems now that I try to burn a DVD it locks up at 37.15% the last three times, or a error message comes up?
Vince Becquiot
January 29, 2007 at 4:44 pmThe DVD error might be something else, or it might not…. BTW, by HD, do you mean HDV, or True HD ?
You also want to look at the CPU load when you are editing. Adobe does list a dual Intel Xeon 2.8 as system requirement for HD. HDV might not be as CPU hungry, but a dual core is really going to be needed as well.
Could you post the error message when you see it again ? And are you just down converting to SD on export? If so, I would recommend down converting to SD before editing (yep a little late now 😉 PP2 does a pretty poor job at it, and then your speed will of course drastically improve.
Vince
South Video
January 29, 2007 at 5:05 pmHi Vince, The system locked up at 37.15% again.
Been editing my Sony FX1 1080 camara for Hi Def editing.
Everything was working fine untill the last 1% of the hour and half movie.
Was just trying to make a down coversion to DVD to watch it then make a dub to tape to capture it back to 1080, did the first half hour to tape ok, but expierincing problems with the second hour.
Been editing off line so do not have error message.
Thanks again for all youtr input!Mark
South Video
January 29, 2007 at 5:10 pmVince, P. S. Editng on a Dell DIM 9200 with a dual Core 2.8GHZ, DCT
John Rich
January 30, 2007 at 12:12 am2.0 Adobe Prem. on Dell 2.8 Ghz and 3 GB of Ram, 500 Hard Drive have a 7Nvida Geforce 7300, thinking of upgrading to 512?
Do you really only have one hard drive? If so, you might get better performance with two drives, one for the system and programs, and the second to put your capture clips on (sorry, but you probably knew that). I was just thinking of any possibility, that might help.
John
JOHNR
