  • Posted by Bruce Botts on August 25, 2013 at 1:30 pm
    trying to install FC Pro HD onto a G5 with over 900 gigs of memory available and I get the error message that there’s not enough memory. I’m not sure how to address this.
    Rainer Wirth replied 13 years ago 4 Members · 3 Replies
  • Neil Patience
    August 27, 2013 at 1:32 am
    When you say 900gigs of memory that refers to drive capacity.. While that should be adequate the message likely refers to the amount of RAM in the machine.
    I think the absolute minimum required for FCP is 2GiGs for working with HD and I think 4 GIGs if you are trying to work with uncompressed HD. (although not sure how that machine would handle those kind of files)
    So checking out how much RAM you have would be my suggestion in the first instance.
    best wishes
    Neil
    http://www.patience.tv
    8 Core MacPro, Kona 3, Tangent Wave, Mackie Universal Symphony 6.5 FCP7
    i7 2.7 Gig MBP (non retina) 16Gigs Ram Blackmagic Monitor Mini Symphony 6.5 FCP7
  • Tom Matthies
    August 27, 2013 at 1:42 pm
    Which version of FCP are you trying to install? I don’t think you can install FCP version 6 or higher on a G5 computer. The G5 has IBM Power PC processors and the newer machines run in Intel chips.
    E=MC2+/-2db
  • Rainer Wirth
    August 28, 2013 at 12:40 pm
    Tom is right!
    cheers
    rainer
    factstory
    Rainer Wirth
    phone_0049-177-2156086
    Mac pro 8core
    Adobe,FCP,Avid
    several raid systems
