Activity › Forums › Adobe After Effects › melting into view or emerging from a liquid effect.
Posted by 3magine on November 23, 2005 at 3:16 amI have a plastic 3d looking button, and i would like it to come into view as if it was emerging from a liquid or melting into view. It is on a white background. How would I be able to achieve this?
3magine replied 20 years, 10 months ago 3 Members · 4 Replies -
David Bogie
November 23, 2005 at 3:12 pmActually 3D or just an illusion of 3D?
A serious bit of design since AE is not a procedural 3D animation/modeling system. REquires you to learn Mr Mercury, Blobbilize, Caustics and Wave World.
In WW, you will animate a rising floor made up of a grayscale image of your button. You will apply the compound effect of WW to a solid layer and either start tweaking Mr.Mercury or Caustics using surface layer controls only.
It’s really hard the first twenty or thirty times and I know of no direct route to accomplish this effect.
bogiesan
3magine
November 23, 2005 at 3:52 pmwell i think just an illusion. Basically all i want to achieve is an effect of my button melting out of nothing into it’s full view. Imagine a candy like button (apple’s buttons are a good example) and have it morph from nothing. This could potentially look as if it’s melting together into a solid, or as if it was sort of emerging from the white background.
Yussef Cole
November 23, 2005 at 6:15 pmOnce again you should really use wave world and caustics. It’s the most realistic looking simulation of this effect without going into 3rd party plug in realm. Look up some tutorials on those effects here and try it out. It will definitely pay off!
Yussef
