Activity Forums Avid Media Composer Mediafiles format between Meridien and Adrenaline
  • Mediafiles format between Meridien and Adrenaline
    Posted by Christopher Tay on August 23, 2005 at 12:20 pm
    Just need to confirm, is the mediafile format common between the Meridien and the Adrenaline ?
    For example, if I capture on an Avid Media Composer Meridien system at 2:1, would I be able to use it on an Avid Adrenaline, and vice versa ?
    -chrispy
    John Pale replied 21 years, 1 month ago 3 Members · 2 Replies
  • Alex Udell
    August 23, 2005 at 12:43 pm
    Hi…
    My understanding is that with the exception of Avid’s new DNXHD format material….all legacy codecs are handled in software by Adrenaline (and dnx may be as well)…
    what this means is YES….you should be able to real your old media just fine on an Adrenaline….
    Alex Udell
    lead demo artist and trainer
    PEI Graphic Technology http://www.profileeast.com
    My Reel: https://alexudell.no-ip.biz
    COMBUSTION EXCHANGE FTP: ftp://combustionexchange.no-ip
    Logon: combustion_user
    PW: learn
  • John Pale
    August 24, 2005 at 5:51 am
    Adrenaline uses the the same Meridien OMF resolutions that you are used to…and it can also work with other types of media, including MXF and DV.
    Yes. You will be fine.
