Activity › Forums › Blackmagic Design › MediaExpress 2.03
MediaExpress 2.03
Posted by Andreas Wideroe on March 15, 2010 at 8:24 amIs finally out. It has 1280×800 screen size! Thank you Blackmagic – it’s finally here! Hooray! 🙂
https://www.decklink.com -> support -> software downloads
/Andreas
Iliya Gitlin replied 16 years, 5 months ago 4 Members · 5 Replies -
Iliya Gitlin
March 15, 2010 at 10:57 amHi, how i can change quality for motion Jpeg avi – standart settings is very low quality – i need capture mjpeg quality equal to DV
Kristian Lam
March 15, 2010 at 12:46 pmHi,
Currently, the MPJEG quality settings cannot be changed. However, the quality should be very good. Maybe it’s worth double checking to see if you have any other codec packs installed on your system. There’s a chance the wrong codec is used due to a conflict.
regards
Kristian Lam
Blackmagic Design -
Iliya Gitlin
March 15, 2010 at 1:06 pmi don’t have installed any other codec or codecpack, quality is low – 30 min SD PAL video file size is 1.6Gb – it’s very small for good quality in mjpeg
Margus Voll
March 18, 2010 at 6:26 amHI.
Then there is something really wrong. You should consider something like 2 times dv size for files.
Margus
