Activity Forums Adobe Premiere Pro MediaEncoder question
  • MediaEncoder question
    Posted by Jim Bachalo on September 9, 2011 at 3:51 pm
    Hi
    ‘Maximum Render quality’ is self explanatory, but when would you want to turn on or off ‘Frame Blending’? Is this the same as the frame blending layers option in After Effects?
    Local is the new global
    Ninetto Makavejev replied 15 years ago 3 Members · 2 Replies
  • Tim Vaughan
    September 9, 2011 at 5:06 pm
    I’m asking the same question; but to my understanding, I think it is when you adjust the motion properties of a clip. So if no clip’s timing is adjusted throughout the timeline, I don’t think you need to apply it. Again, this is my quick interpretation of it 🙂
    Tim
    Apple XRAID, XServe, MacPro, Macbook Pro, XSAN, FCP Studio (7), AVID Media Composer
    Apple Monitors, Flanders Scientific Broadcast, Panasonic AG-AF100
    Adobe Production Premium, Maxon Cinema 4d
    Beer fridge fully loaded.
  • Ninetto Makavejev
    September 9, 2011 at 8:32 pm
    My understanding on “maximum render”, was this is only necessary to tick if you are up/down-scaling. Otherwise the cycles slow down the export with no effect.
    Frame-blending, would be necessary if you are change fps. i.e. the fps of the export is different than that of your sequence.
    But this knowledge is just at a dusty part of my memory, maybe someone can explain/verify.
