Media100i crashing
Posted by Jim Mclean on April 20, 2007 at 2:52 pmIn the last couple of days every time I export to Quicktime my Mac G5 crashes. And if I “Render Range to Bin” it crashes. Any suggestions about what may be going on here?
Christopher Kinsman replied 19 years, 5 months ago 4 Members · 4 Replies -
Accountneedsrealnameupdate
April 20, 2007 at 5:13 pmIs there an error message?
Is it crashing during the audio portion of the export?
If so, does video only work? -
Jim Mclean
April 20, 2007 at 6:41 pmIs there an error message?
The screen darkens and the message says to restart the computer.Is it crashing during the audio portion of the export?
If so, does video only work?After your questions I was able to export just the video. Then when I tried to export just the audio the computer crashed.
Thanks for your help! Jim
Arthur Dent
April 20, 2007 at 10:46 pm“The screen darkens and the message says to restart the computer. ”
That sounds like a OS X kernal panic – How ’bout more of you system details: OS version, QT version, M100 Software Version, Hardware your using etc.
“I was able to export just the video. Then when I tried to export just the audio the computer crashed. ”
sounds like a corrupted audio file – try exporting audio portion of time line in sections (create a range) and see where it crashes, then you may be able narrow it down to the specific audio clip by shrinkig the range that crashes
HTH
A.D. -
Christopher Kinsman
April 22, 2007 at 5:19 amHey Jim, Had that happen to me on my G4 dual 1.42 – OS10.3.9 – M100 8.2.2 It ended up being a bad audio file that I played Bob Barker’s “Higher or Lower” guessing game with till I could single out the little turd! Hope you’re able to get it going! Kind Regards, Chris K.
