Media100 and FCP on New macpro????
Posted by Chris Abolt on May 15, 2008 at 8:33 pmHi all, jumping back on the Media100 train. I have a new mac pro dual quad with kona 3 and atto single fiber channel card with fx5600 Gfx card. I want to run FCP and Media100HD Suite. Any issues or special considerations I need to know when setting up the Kona or slot order configurations I need to know about.
Thanks i advance for the help
ChrisChris Abolt
Motion designer
Abolt MediaFloh Peters replied 18 years, 4 months ago 3 Members · 4 Replies -
Floh Peters
May 15, 2008 at 8:49 pmPut the FibreChannel card into Slot 4, the Kona into Slot 3. You should create different startup partitions for Media 100 and FCP, since the FCP and Media 100 Kona drivers currently cannot be installed at the same time. Otherwise it is pretty straightforward. If you have specific questions, let us know.
Gregg Michaels
May 16, 2008 at 12:36 amI have this setup on a new mac pro, and it’s working flawlessly. You can even install the Media100 codecs on to your FCP partition for easier transition between the systems.
GM
Chris Abolt
May 16, 2008 at 1:37 pmFloh, I should also mention we are running leopard on this machine. Also, I need some clarification on a few things. Are you suggesting a dual boot system with FCP on one side of the partition and Media100 the other? Does this mean I need to install the other (AE, PSD Ill) apps on both sides of the partition? Or is it as simple as partitioning the system drive so both NLE’S can reside without seeing each others drivers.
Would it be better to call and work out some of the details
Any help would be great
ChrisChris Abolt
Motion designer
Abolt Media -
Floh Peters
May 16, 2008 at 2:35 pm[Chris Abolt] “Floh, I should also mention we are running leopard on this machine. Also, I need some clarification on a few things. Are you suggesting a dual boot system with FCP on one side of the partition and Media100 the other? Does this mean I need to install the other (AE, PSD Ill) apps on both sides of the partition? Or is it as simple as partitioning the system drive so both NLE’S can reside without seeing each others drivers.”
Leopard is fine, both for FCP and for Media 100.
The dual-boot option (either via 2 partitions on the same drive or by 2 different drives) is needed to keep the drivers apart. What we usually do is to set up one partition first (e.g. the Media 100 partition), with all software including FCP and the whole Adobe stuff. Then we do activate all apps and make sure everything is registered correctly. Then we do a clone via Carbon Copy Cloner to the second drive, and install the Aja Kona drivers there. They will automatically replace the Aja OEM drivers used by Media 100, and all your activations will stay intact. This way you have all your software on both partitions, and additionally you also have a backup drive in case one of your drives goes bad. You could simply clone back from the other drive and install the missing drivers (either reinstall Media 100 or the Aja Kona drivers).
