Activity Forums Apple Final Cut Pro Media visible in the timeline, but missing from the viewer.
  • Media visible in the timeline, but missing from the viewer.
    Posted by Lucy Slavinsky on August 31, 2013 at 7:56 pm
    Hello all,
    Interesting thing happened that I never faced before. The media does exists in the event browser and my time line, but appeared as the missing one in the viewer. I have attached the screenshot of what I have. Any idea why the viewer doesn’t see the clip?
    Thank you very much in advance.
    Lucy Slavinsky replied 13 years ago 2 Members · 5 Replies
  • Bret Williams
    September 1, 2013 at 1:38 pm
    I don’t see an attachment. But if you have an effect applied that isn’t installed you’ll get a missing error of sorts. Even if the effect is turned off in the inspector.
  • Lucy Slavinsky
    September 1, 2013 at 2:15 pm
    Yes, that’s may be the case!!!!!! I reinstalled FX factory, the newer version and Inspector shows missing effects (add noise). Thanks a lot! So simple! How would you suggest to resolve the issue? When I replace the clip, all other effects are gone too and there is a bunch of them – transformation, opacity and so on. So I have to apply all this effects all over again to at least to 8-9 clips. Is there any smarter way around? I think the ” add noise ” effect is in the effect library.
    Thanks again, because it started to drive me crazy after looking for clips in Finder and see them in place.
  • Bret Williams
    September 1, 2013 at 8:02 pm
    I would just delete the add noise effect. When you delete the missing effect the clip will be visible again. Then you can re-add the effect. Not sure why it would say it’s missing if it’s in the effects browser.
  • Lucy Slavinsky
    September 1, 2013 at 9:06 pm
    Thanks a lot. I’ll let you know what happened
  • Lucy Slavinsky
    September 2, 2013 at 12:50 am
    It worked exactly as you said – I deleted the effect and the clip is visible again.
    Thank you very much once again!
