Activity Forums Avid Media Composer Media Tool listing non-project clips
  • Media Tool listing non-project clips
    Posted by Ron Dylewski on June 21, 2013 at 7:40 pm
    I’m trying to delete a bunch of medium from a big project. I go to the Media Tool, select the RAID the media is on, select Current Project, check all three forms of media and GO.
    Then I get a list of many, many clips which I know are not part of that project.
    Its quite possible I am missing something simple…
    Thanks.
    Ron
    Michael Phillips replied 13 years, 3 months ago 2 Members · 3 Replies
  • Michael Phillips
    June 21, 2013 at 8:34 pm
    What happens if you only select “master clips”?
    Michael
  • Ron Dylewski
    June 21, 2013 at 10:13 pm
    Same issue. I checked to make sure the problem wasn’t coming from “Other Bins,” but it’s not.
    Ron
  • Michael Phillips
    June 21, 2013 at 10:43 pm
    When you look at the PROJECT column in the mediatool window and sort by that, what are the other values in that column?
    Michael
