Activity Forums Avid Media Composer Media Tool does not show project files
  • Media Tool does not show project files
    Posted by Steven Carter on June 14, 2006 at 2:22 pm
    When I launch the media tool in Express Pro and select the drives and project for media I want to see, it only shows me media files for todays date or the last time you created media and not the media since the project was started. Any Idea why this happens. If I want to kill the media for the entire project I can’t. Is there time period setting somewhere? Help please, thanks.
    Geraint Pari huws replied 20 years, 2 months ago 2 Members · 1 Reply
  • Geraint Pari huws
    June 15, 2006 at 12:31 pm
    Unless you’ve got some strange sift set up then it sounds wierd, unless someone has inadvertantly moved media files or rename the origional mediafiles folder…do the clips show if you select all projects, or have you pulled some media across from another project?
