Activity › Forums › Avid Media Composer › Media Tool crashes AVID
  • Media Tool crashes AVID
    Posted by Daniel Schultz on July 10, 2013 at 3:49 pm
    I tried this three times in a row, and each time it crashed at the same point.
    1. Put a sequence in its own bin
    2. Click on Media Tool
    3. Select Master Clips and Pre Computes (on two separate hard drives)
    4. Click OK
    The process starts for a second or two then I get this message: “Segmentation fault” in thread “MainThread” at address 0x0.
    Then Media Composer crashes.
    Any ideas????
    Dan S.
    Robert Pitman replied 13 years, 2 months ago 2 Members · 2 Replies
  • Daniel Schultz
    July 10, 2013 at 8:21 pm
    Update: Now just opening that project gives me the same error and crash.
    I’m assuming something wrong with that particular project, since others don’t do it.
    Dan S.
  • Robert Pitman
    July 10, 2013 at 10:45 pm
    Try a new project and load the bin with the sequence you need. Try media tools again as before. Could it be a damaged MXF database?
