Activity › Forums › VEGAS Pro › Media suddenly appears as green blocks on timeline
  • Steve Rhoden
    January 6, 2014 at 12:34 pm
    Build 770 was recently released. But i would even had recommended
    going back to build 714.
    Steve Rhoden
    (Cow Leader)
    Film Editor & Compositor.
    Filmex Creative Media.
    https://www.facebook.com/FilmexCreativeMedia
    1-876-461-9019
  • Carl Alessi
    January 6, 2014 at 5:20 pm
    Okay…it turns out THAT didn’t work.
    Although changing the plug-in folder’s name solved my MP4 rendering issue, it created a wholly new problem in rendering AVC Mpeg 2 files. I got an error message when launching a Vegas project indicating the streams could not be found; this got worse when I tried to add new Mpeg 2 files to the project, and video streams wouldn’t add at all.
    I’ve changed the name of the plug-in folder back to its proper title, and my Mpeg 2 streams are fine. Of course, Mpeg 4 files are green blocks again.
  • Mike Kujbida
    January 6, 2014 at 5:46 pm
    Carl, this is a stab in the dark but what version of QuickTime are you using? I have 7.7.1 on my machine and mp4 files play fine in Pro 10, 11 and 12.
    I’m asking because the latest version of QT player often seems to break something in Vegas. If you have QT Player set to auto update, I highly recommend disabling this option and stick with what works.
  • Carl Alessi
    January 6, 2014 at 6:13 pm
    Mike,
    I’m running QuickTime 7.7.4.
    Another detail: Some of my MP4s are decoding properly. But ones that I have rendered out of Adobe Captivate screen captures no longer are (although they did previously).
    Here’s the info for the failed, Captivate file:
    Format : MPEG-4
    Format profile : Base Media / Version 2
    Codec ID : mp42
    File size : 454 KiB
    Duration : 19s 200ms
    Overall bit rate : 194 Kbps
    Encoded date : UTC 2014-01-03 22:25:33
    Tagged date : UTC 2014-01-03 22:25:33
    Video
    Format : AVC
    Format/Info : Advanced Video Codec
    Format profile : High@L4.0
    Format settings, CABAC : Yes
    Format settings, ReFrames : 4 frames
    Codec ID : avc1
    Codec ID/Info : Advanced Video Coding
    Bit rate : 193 Kbps
    Width : 1 074 pixels
    Height : 720 pixels
    Display aspect ratio : 3:2
    Frame rate mode : Constant
    Frame rate : 15.000 fps
    Standard : PAL
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.017
    Stream size : 452 KiB (100%)
    Language : English
    Color primaries : BT.709
    Transfer characteristics : BT.709
    Matrix coefficients : BT.709
    Here’s the info for the non-Captivate MP4 that works:
    Format : MPEG-4
    Format profile : Sony PSP
    Codec ID : MSNV
    File size : 8.67 MiB
    Duration : 34s 134ms
    Overall bit rate mode : Variable
    Overall bit rate : 2 132 Kbps
    Encoded date : UTC 2011-04-21 21:37:43
    Tagged date : UTC 2011-04-21 21:37:43
    Video
    Format : AVC
    Format profile : Main@L3.0
    Format settings, ReFrames : 2 frames
    Muxing mode : Container profile=Main@0.0
    Codec ID : avc1
    Bit rate mode : Variable
    Bit rate : 1 999 Kbps
    Width : 720 pixels
    Height : 480 pixels
    Display aspect ratio : 4:3
    Frame rate : 59.940 fps
    Original frame rate : 29.970 fps
    Standard : NTSC
    Color space : YUV
    Bit depth : 8 bits
    Scan type : Interlaced
    Scan order : Top Field First
    Bits/(Pixel*Frame) : 0.097
    Stream size : 8.14 MiB (94%)
    Language : English
  • Manish Ved
    January 8, 2014 at 5:21 pm
    Well, I spoke too soon. The rendered video file is not 3D. I have reverted to out-of-the box settings and tried again. After burning the ISO and playing on a Playstation 3, the media does get recognized as MVC, but the video is still in 2D. Should I revert back to an earlier version of Vegas? Has anyone tried creating 3D Bluray with 770 and succeeded?
Page 2 of 2
