Activity › Forums › VEGAS Pro › Media Replace a 2 Channel Audio Clip With 5.1
  • Media Replace a 2 Channel Audio Clip With 5.1
    Posted by Gene Lati on October 20, 2009 at 4:57 am
    I created a MPG1 proxy file video clip with 2 channel audio. Post edit, when I go to replace the media with the high res video clip with 5.1 or 6 channel audio only 2 channels of the high res source file are replaced. How do I get the other audio channels into the time line?
    The project audio is set to 5.1.
    Gene Lati replied 16 years, 11 months ago 2 Members · 4 Replies
  • D. Eric franks
    October 20, 2009 at 2:53 pm
    What is the source high-res clip? I know I’ve seen all kinds of odd audio-channel things happen with DVD-Video disc ripped MPEG-2 files, including (but not limited to): stereo being mixed up with 5.1, language tracks being interpreted as 5.1, 5.1 tracks being buried under other tracks, hundreds of millisecond sync issues, etc.. It varies depending on the ripped disc, so part of the issue might be Vegas, but part is certainly how the discs were created (some of the strangest problems have been with really old DVDs or discs from Bollywood musicals!)
    Sorry I don’t have a better answer, but let us know the source and someone may have a more specific answer.
  • Gene Lati
    October 20, 2009 at 4:17 pm
    The source was a blu-ray 1080p m2ts file. Using tsMuxer to strip away all but the video and english ac3 5.1. Put the newly created 1080p m2ts on the timeline with the 5.1 (multiple channel) and created a low res mpg1 file 2 channel as the proxy.
    I use the newly created mpg1 file on the timeline to edit and subsequently attempted to replace the proxy with the tsMuxer’s high res 1080p that contains the multiple channel audio and only 2 channels will be replaced. I can’t get all of the 5.1 audio to appear.
  • D. Eric franks
    October 21, 2009 at 12:24 am
    I see: Does the source MTS file come in normally with 5.1 channels? That’ll at least narrow the problem down to “Doesn’t work at all” vs. “It’s a proxy/replace file issue.”
  • Gene Lati
    October 21, 2009 at 5:11 am
    Yes it does D. Eric.
    I suspect I will have to create a proxy file with all the audio tracks but it can’t be done with an mpg1. It will have to be a low res avc with aac 5.1. The only thing is I can’t seem to be able to match the source frame rate of 23.976 in Vegas 9b. It gets goofy that way.
