Activity › Forums › DaVinci Resolve › Media Pool offline mode and consolidate
  • Media Pool offline mode and consolidate
    Posted by Sascha Haber on August 9, 2012 at 8:58 am
    Hi there,
    I love the Media Pool…
    its the core of project organisation and its playback and metadata function are unmatched.
    But it shares the same problem i have with Scratch, the pure amount of data I am using makes it unusable sometimes.
    For example, right now I am online a movie with 44 hours of Alexa clips…roughly 5000 of them loaded.
    After assembling my 5 reels which works just fine I wish to clean it up a little.
    At least i would like to delete all the clips not used by the conform.
    When i use the Update Usage function i see that 80% of the clips are unused.
    It takes almost 5 minutes for Resolve to update those numbers.
    But when I then click on the usage field to sort by usage, Resolve hangs indefinitely.
    One would think it just needs to sort the columns and it would happen in a blink of an eye.
    But somehow it tries to access the media at this point or does something else that kills it.
    My real goal actually would have a function to Consolidate the used media into a new folder.
    Like Scratch does on the project page.
    Analyzing the content, creating a similar structure on disk and copying all files necessary from the network assemble to the local working disk.
    Or in my case, from 5 TB to 1,5 TB 🙂
    A slice of color…
    DaVinci 8.2.1 OSX 10.7.2
    MacPro 5.1 2×2,4 24GB
    RAID0 8TB
    GTX 470 / Quadro 4000
    Extreme 3D+
    ICA Instructor
    https://www.icolorist.com/Sascha.html
    Sascha Haber replied 14 years, 1 month ago 2 Members · 3 Replies
  • Sascha Haber
    August 9, 2012 at 2:07 pm
    Some more info on this…
    Using the Usage tab actually gave me an result after .. 20 minutes or so.
    The next problem is deleting everything that has 0 uses.
    Even when deleting only 3 files it hangs..
    I guess its because it wants to sort em again.
    Maybe someone with a long project can make a test like this to confirm.
    A slice of color…
    RAID0 8TB
    Extreme 3D+
    ICA Instructor
  • Tim Farrell
    August 9, 2012 at 10:53 pm
    Why not use “Add Folder Based on EDLs into Media Pool”?
  • Sascha Haber
    August 13, 2012 at 11:17 am
    Because it doesn’t work 😉
    I have 5 EDLs and it only works the first time.
    After there is media in the pool, the function doesnt add the missing files for the other EDLs.
    But I found a way around that freezing bug.
    1. Load all media
    2. Conform based on EDL or AAF
    3. Update Usage
    4. Sort by Usage
    5. Select all 0 Usage files
    6. Sort by name ( IMPORTANT)
    7. Now delete selected files.
    If you miss point 6, it freezes.
    A slice of color…
    RAID0 8TB
    Extreme 3D+
    ICA Instructor
