Activity Forums Sony Cameras Media out from NX5U for TV
  • Media out from NX5U for TV
    Posted by James Davis on September 24, 2013 at 6:16 pm
    Team,
    I have an event to cover and the client would like to be able to make coverage available to local TV.
    What formats are acceptable and what might the workflow look like. Thanks in advance.
    John Lenihan replied 12 years, 11 months ago 2 Members · 1 Reply
  • John Lenihan
    September 24, 2013 at 6:54 pm
    I assume that you are not supplying live feed to the TV outlet and are looking for something that they will be able to extract portions for airing.
    I would should it 1920×1080 x 60i.
    I usually use LPCM audio, when I am editing, but AC3 audio is more easily recognized.
    How the TV station wants the format is up to them, however, Most can ingest the AVCHD if you copy the whole file structure from the camera when you give it to them.
    Sometimes I dual record onto SD card and onto the FM128 memory and hand the SD card to the client, or tv station in your case.
    John
    John Lenihan
    LeniCam Video Productions
    https://www.lenicamvideoproductions.com
