Activity Forums Avid Media Composer media offline problem #421
  • media offline problem #421
    Posted by Daniel Schultz on January 25, 2014 at 3:24 pm
    Okay, I just don’t know what happened here.
    I just consolidated some clips to a new hard drive.
    Everything’s linking up beautifully.
    I set is so the old clips are the AMA-linked, and the regular clips are linked to the new mxf files.
    Everything’s going swimmingly.
    All the new media shows up.
    Then, in the process of checking other media, I connect and disconnect various drives, including the drive that had the originally-linked AMA files.
    So, now, suddenly, the new-mxf-linked files are offline.
    I try quitting and throwing out the pmr and mdb files, and allowing it to rescan when I reboot.
    I try rebooting my machine. Still offline.
    I know all those newly consolidated mxf files are in the new target drive, because I checked. All 140gb of them.
    So then I try plugging in the original drive that had the camera media from which I AMA’d, and everythign shows up. Except they now show up as linked AMA files, whereas before they showed up in the bin as linked mxf files.
    Anyone have a thought??
    Thanks!!
    Daniel Schultz replied 12 years, 7 months ago 1 Member · 1 Reply
  • Daniel Schultz
    January 26, 2014 at 1:41 am
    Okay…I think I fixed the problem.
    I just opened a new bin and dragged the MDB file into there and all the mxf files linked up in that bin and also in the original bin.
    Phew!
