Activity › Forums › Adobe After Effects › Media offline in Premiere Pro after closing After Effects
  • Media offline in Premiere Pro after closing After Effects
    Posted by Darius Cornean on November 4, 2014 at 1:40 pm
    I have a problem that I struggled for several days.
    I have a project filmed with two cameras in Premiere Pro. I created a nested sequence where we made ​​multicam editing. Then I created several sequences where I put parts from the multicam sequence. Then I sent these sequences in After Effects where I made ​​a noise correction with Neat. I saved the project in AE and then I closed. And in Premiere appeared that all files of those sequences are offline.
    If I keep open After Effects the file in premiere Pro are ok, does not appear media offline.
    Another very important issue, Render works very hard and does not understand why.
    I use CUDA for render. I really need some solutions.
    Thank you!
    iMac 27, 3.5, SSD, 8GB RAM, video card 4GB
    Daniel Waldron replied 11 years, 10 months ago 2 Members · 1 Reply
  • Daniel Waldron
    November 4, 2014 at 9:44 pm
    8GB of RAM isn’t going to set any speed records either. The Neat noise removal plugin is great, but it also is a resource hog. I would shut it off until you are ready to export.
