Activity Forums Apple Final Cut Pro Legacy MEDIA OFFLINE: If I didn’t delete it who did? (SOS)
  • MEDIA OFFLINE: If I didn’t delete it who did? (SOS)
    Posted by Jason Armstrong on January 13, 2009 at 3:28 pm
    Ok, so I’m working away in FCP and I finish a scene. I export the thing to Soundtrack and as sometimes happens, Soundtrack just opens a new project with nothing in it. I flip back over to FCP and the files I had exported and “smoothcam” filtered show as offline. I can’t reconnect as they’re gone.
    I’m irritated, but I go ahead and fire up the original clips to re-insert the video and guess what?
    The originals in the list are missing. Labeled as “Cold Room IV + numeric value, only certain ones are missing, but of course all the crucial ones. They aren’t in the trash and the search doesn’t find them (yes, I included EVER drive).
    So here I am in the middle of a snow storm, with the tapes elsewhere (for safety) and I’m stuck. Where did they go? Can I get them back?
    I’ve wondered about the possibility that smoothcam or soundtrack renamed the originals, but would they be called?
    Any help would be appreciated. I’m… unhappy.
    Paul Allman replied 17 years, 7 months ago 5 Members · 7 Replies
  • 7 Replies
  • Jeremy Garchow
    January 13, 2009 at 3:46 pm
    Can you naviagte to the Capture Scratch folder and see if it’s there?
  • Jason Armstrong
    January 13, 2009 at 4:04 pm
    I have more than one as the project spans multiple HD’s. Search won’t look in those folders?
  • Jeremy Garchow
    January 13, 2009 at 4:13 pm
    [Jason Armstrong] “Search won’t look in those folders?”
    It should, but it’s best to go looking for it just to be sure.
    Jeremy
  • Jamie Pickell
    January 13, 2009 at 5:30 pm
    Jason,
    To quickly find the clips – right-click on an offline clip and select the first option from item properties. This will tell you where the clip last lived when it was connected to your machine. It will also tell you the actual file name of the clip.
    Hope this helps,
    Jamie
  • David Mcgiffert
    January 13, 2009 at 6:40 pm
    Thank you Jamie,
    That is a permanent post-it now
    on the side of my monitor.
    Perhaps most know about it
    but if you are new to this tip – like me,
    it’s a winner.
    David
  • Jason Armstrong
    January 13, 2009 at 7:20 pm
    Tried it out, and manually going there, it’s just not there. I did a recovery (using some $100 program, grrr.) and found one of the six, but with a different name (like totally different) – qt005601.mov (along those lines, not exactly right).
    So I’m stumped. I just know I haven’t deleted anything, so unless the program performed a deletion or changed the filename, I don’t know what to do, and I can’t recapture the footage anytime soon, either.
    Any other pointers/ideas?
  • Paul Allman
    January 13, 2009 at 10:55 pm
    Hi — You can always go into your autosave and pull up a saved project that precedes your foray into Soundtrack. Your clips should be present there — and if you haven’t emptied your trash, check in there.
    Good luck – Paul
    Paul Allman
