Activity › Forums › Apple Final Cut Pro Legacy › Media offline
  • Posted by Gracias on September 12, 2005 at 9:28 am
    Hello,
    I want my offline to be upgraded to online.
    How will I do it? becoz i want only the seq material only to be upgraded not the NG takes. I aso need my ramp, other FX to be intact. I don’t want to do it again on the same thing.
    The same I did by taking my EDL. I ve to do all over again. Any idea how to go aboutit
    Regards
    Pankaj
    Andy Mees replied 21 years ago 2 Members · 1 Reply
  • Andy Mees
    September 12, 2005 at 2:54 pm
    Hi Pankaj
    the method for Onlining is well laid out in the following document, it can explain better than I can …
    https://www.lafcpug.org/basic_onlining.html
    essentially it will show you how and where to usethe Media Manager tool to create a new Online version of your editsfrom your Offline timeline and upgrade your clips to full Online resolution.
    however, as you mention your ramps and FX, its worth noting that there are known issues with the Media Manager tool, particularly with edits containg speed adjustments. You will save alot of time using Media Manager, but you might have to go back in and fix your speed ramps after the upgrade.
    forewarned is forarmed
    cheers
    Andy
