Activity › Forums › Avid Media Composer › Media Offline
Media Offline
Posted by Timothy Lydon on February 24, 2014 at 6:51 pmHello,
I am having trouble with persistent “Media Offline” problems. I just AMA linked a video and made 3 title cards and they all appeared fine on the timeline. I closed the project and opened it again and they all say Media Offline. Could someone help? Not sure what the root of this problem is. Thank you
timothy
Timothy Lydon replied 12 years, 6 months ago 5 Members · 10 Replies -
Ricky Barrow
February 24, 2014 at 7:31 pmI have found on our systems that we must relink each time we reopen a project – other than the hassle it doesn’t affect clip naming or sequence edits.
Ricky
Timothy Lydon
February 24, 2014 at 7:39 pmBut it won’t let me re-link. The option is shaded out, I can’t even choose it… And why am I losing the new title cards each time I close the project? Have you ever run into this problem:
You import a video and then the next video you import takes on the image of the prior video import but with the audio of the new one? I can’t figure out why it is doing this.
Timothy
Ricky Barrow
February 25, 2014 at 1:10 pmI don’t understand the problem of the titles missing. If you create a title it will go to the media folder on a drive; Avid MediaFiles\MXF\1 — so if you are missing media then you don’t have the original drive connected and/or there are corrupt database files inside the numbered folder. Avid can have up to 99 folders (1 – 99) but from what you are saying I would think you would just have one folder (1).
If you do have the drive and folders connectd you can delete these files – .mdb and .pmr and Avid will rebuild them when you open the app – this should eliminate corrupt database files.
Ricky
Hans Sieber
February 25, 2014 at 2:08 pmHi Timothy,
just a guess. Are you working in an Interplay environment? If so it could be dynamic relink that´s getting in your way. Another shot in blue would be a DFS share. Is the AMA linkes Material stored on such a setup?
Hans
Brendan Charles
February 25, 2014 at 4:22 pmFor the titles, with your sequence open, you can go to Clip > Recreate Title Media This should recreate the media for the 3 titles you are missing.
If relinking is greyed out I would suggest going into your bin, right clicking the clip and select ‘Batch Import’ – here you can select the clip in your file system. Are looking at the proper ‘Relink’? – Because there is ‘ReLink’ and ‘Relink to AMA File’ and they are not the same.
As far as what might be causing persistent unlinking… are you working on an external hard drive? If so, what kind? USB? Thunderbolt? ESATA? It could be your hard drive is failing and Avid isn’t picking it up when first opening the program.
Timothy Lydon
February 25, 2014 at 7:16 pmSorry I wasn’t very clear. I created an effect in Marquee ( a title card for my film)… I save this as I always have done but when I close and open AVID, these effects now say “media offline” Twice in the past two days I have gone and deleted the .mdb and .pmr files and this is still happening.
Timothy Lydon
February 25, 2014 at 7:17 pmThank you Brendan, yes I am working on a external hard drive, a Seagate w. firewire 800…
Timothy Lydon
February 25, 2014 at 7:25 pmI am also having importing issues. I wonder if it is my hard drive. I just had AVID open and all my videos were in my bin and fine. I put one clip on the timeline then closed AVID and opened it again and all that media is now offline. This has been happening constantly the last few days. I don’t know what the problem is. Also, There are clips that when I import, there is only a green screen in the source monitor. Should I start the project over on a new hard drive?
Robert Pitman
February 25, 2014 at 11:41 pmHello Timothy,
What version of Media Composer are you using?
What OS are you on?
What codec is this footage, what installed AMA plugin(s) have you installed and what AMA plugins are installed on the system?
To look up your AMA plugin information:
MC7 go to your Project Window and click the “Info” tab look for AMA Plugin info.
MC6.5 and below go Tools>Console, type “AMA_ListPlugins”
Check that you are up-to-date with your AMA plugins by looking at https://www.avid.com/ama
Also please look at ALL the folder and file names between HDD root and media, any odd characters “/\+%” etc?
If your not sure about your HDD, always back it up, see if the new or temp HDD works? Try transcoding to DNxHD, see if all files work (No more green screens – that sounds like a decode issue maybe wrong AMA plugin?)
Good luck.
Cheers,
Robert -
Timothy Lydon
March 4, 2014 at 5:03 pmRobert,
Thank you for replying.
I actually started a new AVID (7) project after I transferred all my footage to a new hard drive. With the old project I had some footage that was imported and some linked which seemed to be giving me trouble. So I just imported 5 video clips that were shot on a JVC700 (1080p, 24fps) but once I bring them into the source monitor I only see a green screen. Is there a setting I have that is causing this? Or am I importing them incorrectly?
Timothy
