Activity Forums DaVinci Resolve media managing RED for a conform?
  • media managing RED for a conform?
    Posted by Michael Stirling on May 17, 2011 at 12:48 pm
    Hi
    I work a lot with RED and would love to know a better workflow than having to bring in all the rushes for the conform or even being able to delete used media from the project. Having 20 hours of RED 4k in my Media Pool can’t be necessary can it?
    When I work from QT FCP projects I media manage them 1st using ‘copy’ to preserve the linked clips from same source feature in Resolve but have a much smaller media Pool
    Mike
    Michael Stirling replied 15 years, 4 months ago 3 Members · 6 Replies
  • Chris Hall
    May 17, 2011 at 3:12 pm
    Clipfinder 2.2 is a great free way to do this (version 2.5 is available for $100, but the free 2.2 will do everything you need). Basically you take your FCP XML and import it into clipfinder and it will identify all your red files in your project (no matter if they are prores qucktimes, transcodes, or proxies). Then you can relink those files to the original .r3d’s; and then copy and paste all the .r3d’s that are in your project into one folder on your hard drive. Then obviously just import only that folder into your media pool in resolve and your good to go with only the red files included in the project.
    They’re are other solutions to this, but I use clipfinder for both FCP and AVID projects that I’m conforming in Resolve. Works like a charm, and its free!
    Chris Hall
    Colorist – Basher Films
    Pasadena, CA
  • Sascha Haber
    May 17, 2011 at 4:10 pm
    But even would be using Storm or REDCineX to truncate the RED files and only use the part you really need.
    That normally eliminates another 90% of unused media if space is tight.
    A slice of color…
    DaVinci 7.1 OSX 10.6.6
    Dual Xeon 2,4 RAM 24 GB
    RAID0 8TB eSata 6TB
    GTX 285 / GT 120
    Extreme 3D+ WAVE
  • Michael Stirling
    May 17, 2011 at 4:16 pm
    thanks for the reply
    i’m not quite there on the method:
    1) open the xml in clip finder
    2) replace mov with r3d – all good and if i right click reveal in finder it points to the r3d
    3) highlight all clips in list and drag to a new finder folder – this gives me a folder of full sized proxies (_F.mov) at about 20kb each rather than a folder of r3d files.
    i’m guessing that it’s step 3 I’m doing wrong but I can’t see what else to do
    Mike
  • Michael Stirling
    May 17, 2011 at 5:20 pm
    thanks for this…
    i successfully got the whole r3d’s files I needed by removing the in and out points then exporting as trimmed r3d’s.
    i also tried trimming and found that i only got the 1st instance of the clip in my Da Vinci timeline with others being red Xed. But apart from that the space saving is immense though it was really about unweildy Resolve projects rather than drive space for me.
    Cheers,
    mike
  • Chris Hall
    May 18, 2011 at 4:40 pm
    Highlight all the .r3d’s in clipfinder, and apple v to “copy”, then “paste” these in the file folder you want. This will copy he .r3d’s and not the proxies. Kind of weird I know, you’d think the click and drag would do thee same thing but it doesn’t.
    Chris Hall
    Pasadena, CA
  • Michael Stirling
    May 20, 2011 at 6:22 pm
    Probably would have taken a month to figure that out
    M
