Activity › Forums › Apple Final Cut Pro Legacy › media manager, slow motion clips
  • media manager, slow motion clips
    Posted by Chuska Esteban on October 4, 2009 at 10:17 am
    Hello:
    I have a problem with the media manager, I have a long project, and I want to make a copy with just the master sequence. When I copy it with the media manager, the new sequence, has reduced the clpis with slow motion, some of them are right, but others are squeezed, I can trim them, and the material is there, but not a the exactly ponts, so I would have to do it manual…and this is going to take a long time!!!
    Any suggestion, to solve this? Am I doing something wrong? Thank you so much.
    Chuska
    Chuska Esteban replied 16 years, 12 months ago 4 Members · 4 Replies
  • Daniel Ludwig
    October 4, 2009 at 1:38 pm
    hi chuska,
    the media manager don´t like speed-ups and speed-downs! there is a big problem with it!
    which version FCP you are using? I haven´t checked this within FCP7, but FCP5 or 6 having permanent problems with it.
    be sure that used clips haven´t got the same names.
  • David Bogie
    October 4, 2009 at 3:00 pm
    Media Manager in FCP7 has solved many of these issues. But it still recommended that you you carefully examine your MM copies for the integrity of speed-adjusted clips, still images, and other effects you do not want to recreate. I always render them and reimport them as self-contained movies but I rarely use Media Manager.
    Media Manager in all previous versions of FCP is terribly flawed, a cruel joke, actually.
    bogiesan
  • Shane Ross
    October 4, 2009 at 9:24 pm
    Yeah, speed changes in FCP 6.x and earlier have issues with speed changes. FCP 7 does a vastly better job in dealing with them.
    Shane
  • Chuska Esteban
    October 4, 2009 at 11:36 pm
    Yes, my version it´s 6.03 and the clips have different names.
    Thank you so much for all yours answers!!!! Now, I know that the problem it´s not my fault.
    So thank you very much.
