Activity Forums Apple Final Cut Pro Legacy Media Manager only connects one clip
  • Media Manager only connects one clip
    Posted by Chad Greene on July 29, 2008 at 4:36 pm
    Media manager is giving me fits and I am wondering if anyone else has this problem or has figured out a good way to deal with it. Here is what is happening.
    I am sending my two hour documentary to another editor for input. To do this, I selected my current timelines and used the media manager to COPY the media to a firewire drive. Before I sent it to him, I wanted to test the project and be sure everything would link up. I disconnected from my drives, making sure the only copy of the media was on the firewire drive. When I opened the project, media manager connected to about half my media with no problem. I was puzzled so I selected five clips that were still offline, and tried to connect. I was able to connect to the first clip in the list, but then the list would clear as though there were no more clips to connect. When I checked my timeline, I found only one clip connected.
    With some more testing I have found that this keeps happening. Media manager will only connect to one clip at a time. If I want those five clips online, I am having to reconnect each one separately. Of course this is causing me great pain (there are 1800 clips), pain I hope someone has found a cure or solution for.
    Chad Greene Mahoney Media Group Minneapolis, Minnesota 2x3GHz Quad-Core, 4GB Ram, OS 10.4 FCP 6, Kona-LH
    Christian Betong replied 18 years ago 2 Members · 3 Replies
  • Christian Betong
    August 4, 2008 at 7:25 am
    I am having the same problem!
    Anyone more seen this?
    Christian Berg-Nielsen
    Sement&Betong
    postproduction
    Norway
  • Chad Greene
    August 4, 2008 at 12:28 pm
    Christian, have you found anything that helps? I have tried it on two different computers here, and was tempted to try to try an older version of FCP using an XML.
  • Christian Betong
    August 4, 2008 at 1:49 pm
    Tried with an XML on another computer. Same problem. I just reconnected them manually, boring but now it works. I can make em offline, move them and still reconnect. Weird. I put the reconnect command to a keyboard shortcut. I guess you could script a macro that would do it automatically. It took me 20 minutes…
    Sement&Betong
    postproduction
    Norway
