Activity Forums Apple Final Cut Pro Legacy Media Manager issues again
  • Media Manager issues again
    Posted by Chris Stevens on May 31, 2009 at 8:13 am
    Steve Eisen kindly advised me never to use Media Manager to recompress, but to use Compressor. Having tried doing this, I can’t see any difference in the result. Media Manager appears to be a faster & easier workflow. Could someone please explain why Media Manager is not to be used?
    Cams: Z1, EX3, HDX900.
    Post :FCS6, Media 100HD V12, AE7, 12TB Sata Raid & monitoring to die for!
    Chris Stevens replied 16 years, 11 months ago 3 Members · 5 Replies
  • Nick Meyers
    May 31, 2009 at 8:17 am
    i would have thought that MM didn’t use the best settings to recompress.
    if you are compressing DOWN, then i don’t see a problem with using MM.
    if you are compressing UP, then i’d say compressor offers better options, in terms of scaling.
    nick
  • Chris Stevens
    May 31, 2009 at 9:10 am
    Thanks Nick. As I’m going from XDCAM EX (1920×1080) to ProRes HQ (same frame size) – there’s no scaling involved, so Media Manager would be ok? I follow your thinking re upscaling though.
  • Steve Eisen
    June 1, 2009 at 1:34 am
    Chris
    I suggested not using Media Manager to recompress because Media Manager gets it famous name of “Media Mangler” when you use move, recompress or use existing.
    Go to the iTunes store and download a Podcast from MacBreak Studio dated 1/29/09. Tips and techniques for successfully using media manager.
    Steve Eisen
    Eisen Video Productions
    Board of Directors
    Chicago Final Cut Pro Users Group
  • Nick Meyers
    June 1, 2009 at 3:46 am
    Media Manager is actually quite stable and predictable for jobs such as these.
    MM can get tricky when delaing with large sequences or projects,
    but for simple moves, copies, or even a recompress like this, it’s fine.
    buit it’s a good idea to read up a bit on MM.
    i havent done much recomprressing,
    but as it’s making a COPY of the media there’s not much that could go wrong, IMO.
    if you need to reconect to hte original media doan hte track,
    the basic settings to use would be:
    RECOMPRESS
    DONT delete unused
    BASE MEDIA FILE NAMES on existing file names.
    if you have added any log notes to the clips,
    or changed their names (however i’d recomend you dont do that)
    then you would also ask for a new project to be made.
    cheers,
    nick
  • Chris Stevens
    June 1, 2009 at 11:13 am
    Thanks guys for your advise & link to MacBreak Studio.
