Activity › Forums › Apple Final Cut Pro Legacy › Media Manager is not doing what I expect it to do
  • Media Manager is not doing what I expect it to do
    Posted by Gareth Randall on February 3, 2013 at 12:30 pm
    I’ve got a project for which the source video is a single 41 GB MXF file using the XDCAM HD422 codec which I’ve then subclipped (it’s a movie). I’ve cut a 35-second promo for this movie and now I want to consolidate and archive the project to get back a big chunk of that 41 GB.
    Problem is, when I right-click on the sequence and choose Media Manager, it doesn’t indicate any reduction in file size for the modified project:
    I’ve tried every combination of the options, and still nothing. The movie master clip does have a Reel number (Media Manager will show the same behaviour if you don’t set a reel for each master clip).
    Any ideas for getting round this will be gratefully appreciated…
    Gareth Randall replied 13 years, 8 months ago 3 Members · 4 Replies
  • Steve Eisen
    February 3, 2013 at 1:18 pm
    It is acting normally. Subclips are just references to the big file. It doesn’t actually cut it up into smaller clips.
    Steve Eisen
    Eisen Video Productions
    Vice President
    Chicago Creative Pro Users Group
  • Gareth Randall
    February 3, 2013 at 3:31 pm
    I think you may have misunderstood my point. I only mentioned the subclips in passing as background to my workflow. The key issue here is that I have a 35-second promo cut using a 2-hour movie (a single 41 GB source clip) and I want to use Media Manager to create a new project and copy over only the 35 seconds of media actually used in the sequence.
    I suspect the problem is that the source clip is MXF rather than QuickTime. I’m rewrapping it as a QT now, so I can take the MXF offline and reconnect to the MOV and see if that makes any difference.
  • Shane Ross
    February 3, 2013 at 10:04 pm
    That’s it. FCP can only media manage footage that is in an editing codec, or has a reel number. H264 footage FCP can’t manage. MXF media accessed via Calibrated or Raylight also are problematic.
    Shane
    Little Frog Post
  • Gareth Randall
    February 4, 2013 at 5:57 am
    [Shane Ross] “FCP can only media manage footage that is in an editing codec, or has a reel number
    My media satisfies both those criteria. As suspected, it turned out to be the fact that it was using an MXF wrapper. I just rewrapped the MXF as a QT, reconnected, and now Media Manager has done its stuff – 41 GB reduced down to 413 MB.
