Activity Forums Apple Final Cut Pro Legacy media manager FCP 5.1
  • media manager FCP 5.1
    Posted by Peter Hall on May 1, 2008 at 10:08 am
    Hi folks, I’m new here, have a nasty one I imagine no one will want to answer.
    I attempted for the first time to gain some space using media manager, The drive was almost completely full (500 mb left) and during the media managment process I kept getting messages telling me it couldnt process certain files as there was no room to render. I set it to skip all these files.
    At the end of the process I did gain some space but media manager also made 176 clips offline or deleted altogether as I cannot find them anywhere on the HD. I have tried looking in the capture scratch folder, they are missing altogether. Even “reconnect media” cannot find them anywhere.
    My settings were:
    I clicked on a sequence in browser, and then media manager.
    the following settings were checked in the active media manager fields:
    Media
    use existing (media referenced by selected items)
    delete unused media from selected items
    use handles 00.00. 01.05
    Base media file names on: existing file names
    The other fields were inactive.
    Any advice on the correct proceedure would be most welcome.
    Thanks in advance,
    Peter
    MBP 2.2, ext 250G IDE
    Peter Hall replied 18 years, 4 months ago 5 Members · 5 Replies
  • Tom Wolsky
    May 1, 2008 at 11:11 am
    You’re in real trouble here and will probably have to recapture material. Use existing is highly dangerous and should not really be used, and certainly not for a whole or large project, but used selectively. Your real solution is to get more drive space, bigger drives or an array. Don’t skimp and cut corners when you’re running short on space it will lead to nothing but trouble.
    At this stage I’d just try to piece together what I can, get another drive and re-capture what’s lost.
    Good luck.
    All the best,
    Tom
    Class on Demand DVDs “Complete Training for FCP6,” “Basic Training for FCS2” and “Final Cut Express Made Easy”
    Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 3.5 HD Editing Workshop”
  • Walter Biscardi
    May 1, 2008 at 11:20 am
    [Tom Wolsky] “You’re in real trouble here and will probably have to recapture material. Use existing is highly dangerous and should not really be used, and certainly not for a whole or large project, but used selectively. Your real solution is to get more drive space, bigger drives or an array. Don’t skimp and cut corners when you’re running short on space it will lead to nothing but trouble.
    At this stage I’d just try to piece together what I can, get another drive and re-capture what’s lost.”
    I have to agree with this assessment. Using Media Manager to “save space” is not what it’s designed to do. It’s designed to archive an entire project or move a project from one system to another.
    Using it to clean up a drive that only has 500MB left shows poor media management on your end. You need a much larger array.
    Walter Biscardi, Jr.
    Biscardi Creative Media
    HD and SD Production for Broadcast and Independent Productions.
    STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
    Read my Blog!
    View Walter Biscardi's profile on LinkedIn
  • Dylan Reeve
    May 1, 2008 at 1:35 pm
    [walter biscardi] “I have to agree with this assessment. Using Media Manager to “save space” is not what it’s designed to do. It’s designed to archive an entire project or move a project from one system to another.
    Using it to clean up a drive that only has 500MB left shows poor media management on your end. You need a much larger array.”
    A fair call… But boy, a media manager that to all outward appearances seems likely to be able to do this in fact does the opposite and sabotages the sequence you were trying to protect? Aiiieee.
    For what it’s worth, no matter how much space I have available, it never seems to be enough… The data will expand to fill the space available, or something like that 🙂
  • Arnie Schlissel
    May 1, 2008 at 2:42 pm
    [Dylan Reeve] “For what it’s worth, no matter how much space I have available, it never seems to be enough… The data will expand to fill the space available, or something like that :)”
    Repeat after me: “Drives are cheap.”
    A bare 1TB drive is around $240 for a Seagate Barracuda. A Hitachi is maybe $310. You can build an 8TB array for something like $2500 or $3k. You can build an indivudual 1TB firewire drive for around $300, or you can buy one for maybe $350.
    Arnie
    Now in post: Peristroika, a film by Slava Tsukerman
    https://www.arniepix.com/blog
  • Peter Hall
    May 1, 2008 at 3:42 pm
    thanks for your post – point well taken. I am new to FCP Regardless of my poor management, if Media Manager isnt useful for removing unused media, are there other applications or tricks that can help in this laborious task? As another poster commented, MM did exactly the opposite of what was purportedly asked of it – made a project completely useless. Purchasing more storage is next on the agenda, though it doesnt solve the issue of freeing up space on that drive without corrupting projects. I am starting to suspect that FCP doesnt like deleting unused files due to its complex file sharing protocol. Thanks, Peter
