Activity › Forums › Apple Final Cut Pro Legacy › Media Manager and Multiclips
  • Shane Ross
    October 24, 2009 at 5:27 pm
    If I used Multiclips or Merged clips, I might, but I don’t…so..sorry.
    I media manage all the time…but not with that stuff.
    Shane
  • John Pale
    October 24, 2009 at 8:14 pm
    Media Manager cannot trim anything without a reel name.
    Do the XDCAM clips have anything in the reel name column?
  • Nick Meyers
    October 25, 2009 at 1:01 am
    Hi, Kevin.
    it should work.
    as john mentions, you need a reel# on all clips.
    one more thing to try would be a two-stage media manage.
    when you “Collapse” a multiclip, the clip actually remains a multiclip, just collapsed (it can be UN collapsed)
    in XMLs, the clip is still flagged as a multiclip,
    so im guessing a collapsed multi would survive media management, and still be able to be un-collapsed.
    however, in the Media Manager there is a check box to include other multiclip angles or not.
    try that and see if it helps.
    otherwise a 2-step plan would be to:
    COPY
    DONT DELETE UNUSED
    DONT INCLUDE MULTICLIP ANGLES
    and then:
    COPY
    DELETE UNUSED
    all the best,
    nick
  • Kevin Monahan
    October 25, 2009 at 6:51 am
