[David Michael] “1. h264->prores proxy”
How did you do the initial conversion?
Well, besides that, the workflow looks wrong to me. If you want to do offline/online with FCP, then you need to do it ENTIRELY INSIDE FCP. Meaning use Log and Transfer to bring the footage in as ProRes Proxy. Then edit, then media manage to an HQ sequence, or 4444 sequence (4444, BTW, is WAY OVERKILL for 5D footage. As is HQ. You gain zero quality over regular ProRes, but 1.5 to 3 times larger file sizes).
But if you are going to Color, don’t use PR4444…there is a bug with Color where it clamps any 4444 footage to 98 IRE and 0 IRE…and brightening the footage makes it yellow, not white. HQ doesn’t suffer this problem.
Your idea of using outside apps to do the converting is adding more work and headache to your online…as you can see. Getting the footage to reconnect is going to be quite a task….unless you invest in third party software:
https://www.videotoolshed.com/?page=products&pID=41
Sorry, bad plan IMHO. Got off on the wrong foot from the start.
Shane
