Activity Forums VEGAS Pro Media Manager %$$%@$@ 2 Problems
  • Media Manager %$$%@$@ 2 Problems
    Posted by Anthony Uccello on December 10, 2008 at 1:26 am
    #1
    I spent 2 hours sorting out my stock footage and I hit delete on one of the tags but it had the wrong one selected and it deleted ALL my work!!
    It won’t let me undo. WTF is up with that? Is there no way to SAVE your library set up so you don’t have to do it ALL over incase of an accidental delete?
    #2. The search limit is set, but can I browse BEYOND it? I only see 1000 or the 4000 or so files, will I have to re-scan at a higher limit to gain access to them?
    John Rofrano replied 17 years, 9 months ago 2 Members · 1 Reply
  • John Rofrano
    December 10, 2008 at 9:33 pm
    Can’t help you with #1.
    For #2 the media manager is not designed for general browsing. It is for doing a search and then browsing the results. If your search returns 1000 results you probably need more search criteria. So it was not intended to be a general browser. You can do that with explorer. You could always increase the search limit if that’s how you want to use it.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
