Activity Forums Apple Final Cut Pro Legacy media management question about edl importing etc
  • media management question about edl importing etc
    Posted by Bob Flood on January 7, 2006 at 7:30 am
    Hi Guys
    love this forum!
    I have a job that currently resides on a discreet edit system and i need to move it to FCP 5.0.4
    I can export edls of the sequences, of which there are several
    as well as excel spreadsheets of additional footage i want to keep online
    I would really like to capture all the clips in the spreadsheet
    relink the edls to this footage, then recapture whats missing
    if the process is not exactly done this way ok,i would like to know whatever i can do to avoid captureing the footage twice ie once form the spread sheets and again from the edls
    i have looked through here and ken stones site, and there is nothing that helps my specific needs.
    it seems that reconnecting media to clips based solely on timecode and reel numbers is difficult. is this the case?
    if anyone can point me to a resource or a website that has an eplanation that would be great.
    or is this a lot easier than i think?
    thanx in advance
    bee eph
    Bob Flood replied 20 years, 8 months ago 3 Members · 6 Replies
  • David Roth weiss
    January 7, 2006 at 8:43 am
    Bob,
    Just curious, how many events on your spreadsheet???
    DRW
  • Bob Flood
    January 7, 2006 at 6:54 pm
    DRW
    dood! i was hoping i’d get you to chime in here eventually. all we need is palmos and its old home week!
    man im intigued by this FCP. it does a bit more than edit in real time, and im sure eventually i’ll get my chops down on the interface. but as to your question:
    I have about 5 EDL’s, with a mix of interviews, animation, lower third tga’s and b roll cutaways. I’ll convert the animation out of edit to animation qt,
    and the tga’s should import so all i need to do is capture the interviews and b roll. which is probably about 200 clips,
    i also have a spreadsheet with about 300 to 500 clips (you should have seen it before i narrowed it down, had about 2000!)
    so, just to re-iterate, some of the shots on the EDL’s are common ie the same shot appears in more than one EDL, as well as being common to shots in the spreadsheet, overall probably 100-150 shots on the EDLs are also in the spreadsheet. (the edls are final edits, the spreadsheets are outakes and alt versions not used, as well as whats in the EDLS)
    the only elements that are JUST in the EDL, as far as originating on tape, are the interviews.
    so without delving too deeply into the workings of this whole FCP Master Clip, Sub Clip, Independent Clip thing. I dont know how to save myself from having to recap 150 shots, or more, twice.
    soory about long wind, but i wanted to make it clear. I also want to make it clear that advice directly given here would be great, but i would be happy with web links to info as well!
    thanx again
    bee eph
  • Mark Raudonis
    January 7, 2006 at 7:23 pm
    Bob,
    What you’re essentially asking is, “How do I move my discreet project to FCP?”
    check out Automatic Duck. (www.automaticduck.com) They have many different conversion programs that may address what you’re trying to do.
    mark
  • David Roth weiss
    January 7, 2006 at 7:27 pm
    Bob,
    Its funny that so many Edit*ors think everything has be rendered, when in fact FCP is at least as RT as Edit* if not more so as you said.
    I wish I could say my luck with EDLs from Edit* had been stellar, but alas, migrating jobs between the boxes ha been somewhat more dificult than I would have hoped for. I had things that winded up missing, and it was a pain to figure out what was lost. Most importantly, test a few EDLs first, and figure out which flavor works best. I can’t remember if I had better luck with CMX lists or some other flavor, but some work and others simply don’t. You will know immediately, as the timeline will eoither be populated by lots of events (working), or by one or two(not working). My second pick worked, but I’m so busy today I can’t dredge up that memory clearly. As for the spreadsheet, that one I have no idea about???
    DRW
  • Bob Flood
    January 8, 2006 at 4:08 pm
    DRW
    thanx!
    i am sure the the rendering issues are merely because the project i am in now was not set up properly
    as for EDLs, i had read elsewhere that FCP is finnicky about what edls to accept
    thanx!
  • Bob Flood
    January 8, 2006 at 4:14 pm
    thanx mark
    unfortunately, i have no budget in this case to buy software. its really more for my convenience.
    i think the program may not work, as the NLE i am coming from never really
    got “project compatible” with the other discreet products, and was discontinued years ago (yet it is still used here and elsewhere)
    I beleive that before the product was dropped, the best i could do was transfer sequences from edit to smoke, not whole projects
    thanx again
    If i figure a way to do it, ill post it here
    bee eph
