Activity Forums Apple Final Cut Pro Legacy Media Management Problem with FCP 7 / Merged Clips change their names
  • Media Management Problem with FCP 7 / Merged Clips change their names
    Posted by Manuela Lupini on April 26, 2011 at 2:21 am
    Hello,
    I’m currently working in a project and I’m in hell because all of the merged audio clips have adopted the name of the video clip that are linked to them.
    First I synced all the video clips with the audio clips and linked them. Until then I had no problems. Afterward, I had to switch from a huge hard drive to a smaller one (because I was going to travel for a couple of days) hence I used the Media Manager to extract the clips from the sequences that I was going to edit, because I didn’t want to miss the deadline.
    The problem came when I switched back to the original disk. When I started reconnecting the media, the audio files automatically renamed themselves after the video file that they were linked to. I did try to reconnect them manually, but it hasn’t worked either. The problem is that after I used the Media Manager the merged clips won’t reconnect properly.
    I’m desperate because I don’t know what is causing this mess,
    can somebody help me?
    Does anyone know how to solve this problem?
    Thank you very much
    VS
    Michael Dervenski replied 13 years, 2 months ago 2 Members · 1 Reply
  • Michael Dervenski
    July 8, 2013 at 12:32 pm
    Hello to all of you 🙂
    I have absolutely the same problem.
    Does someone have a solution in mind?
    Thank you very much in advance 🙂
    Yes I Do But Not With You
