Activity › Forums › Apple Final Cut Pro › Media Management in FCPX
  • Craig Seeman
    July 15, 2011 at 7:34 pm
    Interesting that it’s FAT32. Macs should be able to write to FAT32 although there’s a 4GB file limit. I wonder if there’s something specific to FCPX that blocks FAT32 due to the file size limit. The OS itself doesn’t prevent writing to FAT32 drives though.
  • Jeremy Garchow
    July 15, 2011 at 7:38 pm
    [Craig Seeman] ” I wonder if there’s something specific to FCPX”
    FCPx only allows HFS+ drives for events/media.
  • Craig Seeman
    July 15, 2011 at 8:12 pm
    [Jeremy Garchow] “FCPx only allows HFS+ drives for events/media.”
    Although David can apparently import from FAT32. I’d guess that if one disabled Copy Files. . . in preferences it would successfully create aliases pointing to the drive although obviously the Event would be on HFS+ drives.
  • David Burch
    July 15, 2011 at 9:35 pm
    My guess is that the 4GB file size limit is the reason. Video files can easily grow much larger than 4GB, and because of this FAT32 would pose a serious problem for an event, even if your individual clips are small in size. Render files also go into the event, and a longer project made up of small clips can have large render files.
  • Jeremy Garchow
    July 15, 2011 at 10:03 pm
    [Craig Seeman] “Although David can apparently import from FAT32. I’d guess that if one disabled Copy Files. . . in preferences it would successfully create aliases pointing to the drive although obviously the Event would be on HFS+ drives.”
    That would be the way, but the event has to be on an HFS+. If you bring that drive to another machine, you are hosed.
    Jeremy
  • Matthew Celia
    July 19, 2011 at 12:20 am
    FAT32 formatted drives also operate much slower than HFS+ formatted drives. Something to do with how it deals with files, can’t remember what.
    Trust me, you want to edit with HFS+.
    FCP Guru
    http://www.fcpguru.com
Page 2 of 2
