Activity › Forums › Apple Final Cut Pro Legacy › Media Management
  • Captain Mench
    May 19, 2006 at 11:31 pm
    Partial clips off the tape? Or partial clips off the captured material?
    Partial clips off the tape is done in Log and Capture. Partial clips off the captured material can be done with either markers or subclips.
    Is that what you want?
    CaptM
  • Nick Meyers
    May 20, 2006 at 12:05 am
    select the offline sequnce, or bin of clips, then open MM.
    use “Create Offline:” mode (pull-down menu)
    select “Delete unused”
    un-tick everything else
    Base Media File Names on: Clip Names
    in some versions of FCP this is broken,
    and it cant trim offline clips.
    it works for me in V5.04
    cheers,
    nick
