Activity › Forums › Adobe Premiere Pro › Media Managed Transcode from PP
  • Media Managed Transcode from PP
    Posted by Francois Driessen on January 31, 2013 at 5:00 pm
    HI there, guys
    This is not a new question. But a serious shortcoming of PP if its still not doable. Hope someone in the herd has a solution yet? You guru Cows have a solution yet?
    Cutting MTS directly on the PP timeline. Would like to media manage only the clips that made it into the final cut to ProRes for going to Resolve & for FX finishing. Ideally I’d like to end up with a new PP sequence that references to the new ProRes files (with a little bit of handles added).
    This was a standard thing in FCP7.
    I guess I could export an FCP XML from PP. Convert it to FCPX XML with Resove and try a Transcode Media Management through FCPX… But what a round-trip… 🙁
    Francois
    FireTrigger Inc.
    https://firetrigger.com
    Francois Driessen replied 13 years, 8 months ago 2 Members · 2 Replies
  • Kevin Monahan
    February 1, 2013 at 7:49 pm
    If the footage is Long GOP based, it cannot be trimmed. As far as transcoding, why do you want to do that and lose a generation?
    Kevin Monahan
    Sr. Content and Community Lead
    Adobe After Effects
    Adobe Premiere Pro
    Adobe Systems, Inc.
    Follow Me on Twitter!
  • Francois Driessen
    February 1, 2013 at 8:33 pm
    Yes, its long GOP of course. As mentioned, It’s MTS (AVCHD). It can be transcoded and trimmed for sure. If you can bring in a long GOP file into AE / or a NLE like PP and trim it there you can trim it via the Media Encoder. (Not sure what you’re getting at… ?)
    Converting to short GOP has many advantages downstream for post. if you do a good quality cross-code to a codec like ProRes you will not see a degradation at all. In my case I want to send the files to RESOLVE for grading and that does not accept MTS streams.
    Francois
    FireTrigger Inc.
