Activity Forums Apple Final Cut Pro Legacy Media manage for travel?
  • Media manage for travel?
    Posted by Jay Williams on April 4, 2009 at 1:50 am
    Hi, I’m hoping I can get some advice here on whether this is possible…
    I’ve got a feature length project spread out over 3 drives, and I need to continue working while traveling.
    I’d prefer not to transport all 3 drives, so I’m wondering if there’s a way to copy the media used in my sequence from drives #1 & #2, and copy them to drive #3.
    Ideally I’d like to be able to relink to the original media spread out over 3 drives once I return home. Is this possible under the current Media Manager?
    Is it even possible to pick which drive you want to copy/move media from when you select an entire timeline? It looks like media manager wants to also copy the media from drive #3 back on to drive #3.
    Hopefully I’m wording this to make some sense. Thanks for the help sorting this out.
    Jay
    Tom Wolsky replied 17 years, 5 months ago 2 Members · 1 Reply
  • Tom Wolsky
    April 4, 2009 at 8:19 am
    That would be a pretty stupid if that was the case. You can pick whatever destination you want at the bottom of the media manager window.
    You said this is a feature, does it use separate audio and merged clips. If so you want to do some tests as MM has been problematic with merged clips.
    All the best,
    Tom
    Class on Demand DVDs “Complete Training for FCP6,” “Basic Training for FCS2” and “Final Cut Express Made Easy”
