Activity › Forums › DaVinci Resolve › media manage
media manage
Posted by Paulson Lang on June 16, 2012 at 5:35 pmHi,
How to media manage r3d files from avid edl?
PJRohit Gupta replied 14 years, 3 months ago 6 Members · 10 Replies -
Juan Salvo
June 17, 2012 at 4:32 amYou mean as in truncating the clips to just the used bits? You need to use redcine-x, it’s the only app able to export r3d files. But you’re probably better off keeping the r3d media on your clients drive… and then rendering out just the used bits to DPX or delivery format of choice.
Online Editor | Colorist | Post Super | VFX Artist | BD Author
Paulson Lang
June 17, 2012 at 7:24 amThanks for the information. Can u plz explain the procedure in redcinex?
PJ
Dan Moran
June 17, 2012 at 10:09 amResolve 9 trims r3d files nicely!
Dan Moran
Colourist
Smoke & Mirrors: London
http://www.danmorancolor.com/blog -
Sascha Haber
June 17, 2012 at 11:54 amGimme 🙂
A slice of color…
DaVinci 8.2.1 OSX 10.7.2
MacPro 5.1 2×2,4 24GB
RAID0 8TB
GTX 470 / Quadro 4000
Extreme 3D+ICA Instructor
https://www.icolorist.com/Sascha.html -
Sascha Haber
June 17, 2012 at 3:38 pmWell its dead simple, you load the .edl , all your clips available and assemble them.
Then you export the clips on the timeline with the amount of handles into a new folder…
I always do that to keep my working directory as light as possible.
Crucial for remote grading too.A slice of color…
RAID0 8TB
Juan Salvo
June 17, 2012 at 7:43 pm -
Paulson Lang
June 18, 2012 at 2:05 amIn that procedure only still frames are exporting. Can u tell me in the procedure in detail?
PL -
Sascha Haber
June 18, 2012 at 7:05 amHave you read the manual and did some tests on your own ?
We would love to correct mistakes and help developing , but personally, I learn more if I discover things first by digging into it.A slice of color…
RAID0 8TB
Chris Martin
June 20, 2012 at 6:49 pmHey Dan,
Does v9 trim down the physical R3D file itself or is it doing a virtual trim within the media pool? If it’s actually able to moe just the R3D select then using an EDL to add R3D files into media pool and then copy locally sounds like the way to go.
Can’t wait for 9!
Cheers, Chris
Rohit Gupta
June 21, 2012 at 2:08 amIt’s making a physical copy of the Red file – just the extents used in your edit, plus handles if you want them. It’s a fairly fast process since it’s working on the Red compressed data directly.
