Activity Forums Adobe Premiere Pro Media location changed.
  • Media location changed.
    Posted by Alistair Macdonald on June 13, 2015 at 7:48 pm
    I am a new user experimenting to decide how best to structure my work flow.
    I import media from a file on drive A create a project and store the project
    Copy the file with the media to drive Z
    Come back later and open the stored project get media offline message as expected
    I can import the media from the file on Z but it does not link is there an equivalent of re-link or what should I do ??
    My plan was to archive a completed project with all its media on an off line drive, and if I needed to work on the project again split the project and media on to separate drives to work on the project.
    I would appreciate any advice…for a new user( not cloud ) .
    Alistair MacDonald
    TAMS
    750 14th Street SW
    Loveland CO 80537
    1 970 669 6553
    Richard Herd replied 11 years, 2 months ago 2 Members · 1 Reply
  • Richard Herd
    June 15, 2015 at 7:38 pm
    [Alistair MacDonald] “I would appreciate any advice…for a new use”
    The project manager is super important and an easy to use tool.
    Your other option is to put everything, even the project file, Project > Settings > Scratch Disks …
    Make sure it is all set to Same as Project. Then when you archive, you dump the entire folder wherever you want. When you’re ready to work again, dump the the whole folder back on your media drive.
    Are you using the Media Browser to import media?
