Activity Forums VEGAS Pro Media has changed itself around???
  • Media has changed itself around???
    Posted by Jack James on May 23, 2008 at 9:22 am
    Hi
    So I’ve opened up vegas this morning and for some reason the media on my timeline has swapped itself around. All my cuts are exactly where they were yet the media has swapped itself around, so the wrong footage is in each ‘cut’ Does anyone have any idea whats going on??
    Jack James replied 18 years, 4 months ago 2 Members · 2 Replies
  • Jeremy Rasnic
    May 23, 2008 at 1:43 pm
    I have not seen this before, but you can try a couple of things.
    1. Try your veg.bak file (it should be with your veg file and you can see it if you choose to show hidden files).
    2. Check to make sure your drive letters did not change if you rebooted or unplugged an external.
    3. Move your footage to a different folder, open up Vegas and it should ask you for the missing files- point it to the new folder(s) containing your footage.
    I hope one of those helps.
    j razz
  • Jack James
    May 23, 2008 at 1:55 pm
    Hi Jeremy
    Thanks for the reply, I’ll try these asap and let you know what happens
    Thanks again
